Long Beach gear
Posted: Wed Jun 14, 2017 7:40 am
That long beach is hard on gear
Windsurfing, kiteboarding and weather discussions
https://windisgood.com/phpBB3/
I wonder if carbon bases, especially longer ones, flex enough that they don't bend/kink/snap like aluminum ones. Aluminum booms are brutal for breakage. Carbon is the way (initial $$$$$ hit but over long run possibly cheaper).C36 wrote:Sorry to see the damage.
On the bright side if the base was carbon it likely would have broken resulting in rig/board separation (and potentially more sail/mast damage in the shore break) and better the tail broke as it is cheaper to replace than the arms.
I thought the same thing, until I saw three extensions crushed in the waves, all carbon. I have seen aluminum extensions bend (like Gwind's, but haven't seen any break). As for carbon booms - Ben did two last summer and Chris Klohn warranted three from memory (big guy snapped them doing forwards).winddoctor wrote:I wonder if carbon bases, especially longer ones, flex enough that they don't bend/kink/snap like aluminum ones. Aluminum booms are brutal for breakage. Carbon is the way (initial $$$$$ hit but over long run possibly cheaper).
