Getting outside of the breakers
Hey all, looking for some tips on wave sailing. I am a bit slow at getting into the foot straps, which is causing some problems while trying to get outside of the breakers. I keep jumping foam piles before I can get in the straps and then crash just inside. Any tips or suggestions on how to reduce the carnage would be cool
The biggest favor you can do yourself is time the lulls before you head out. That way at least you are figuring it out on the least amount of white water as possible.
Second to that, head downwind for some speed then stomp the tail of the boat just prior to the white water, to pop up over it. Often you'll get rounded up wind a bit by the wave, so you'll quickly have to get your weight forward and open up the sail right after you pop over.
Ultimately though, it's just practice that is going to get you through it.
I found the applicable sections of this guide useful for learning to sail in real surf:
Oregon Coast Windsurfing Guide 2009
- thankgodiatepastafobreaky
It's all about when to go through or over the wave. When you decide to stop bearing off and going for it wait for the white water after the peak has gone by. Or you can get over before the peak but that can be dicey. There really is only one very dangerous spot, the peak (and the barrel just after), where the wave packs tons of punch. Turn and bear off and ride the wave or whitewater if you are not going to make it.
- Been thanked: 10 times
Re: Getting outside of the breakers
where would these "breakers" be?bamfieldave wrote:problems while trying to get outside of the breakers
- BigD
waves
Get this DVD:
Chapter 1 is called " Getting out. He suggests only putting your back foot in the strap and keeping the front one out.
http://www.wavesailingsecrets.com/preview.cfm
I think someone with "Bamfield" in their BWD name has quite a choice of breakers. Now breakers with wind might be harder to come by....KUS wrote:where would these "breakers" be?bamfieldave wrote:problems while trying to get outside of the breakers
Dave are you keeping your legs really supple when you hit the whitewater? I found thinking about a deep knee bend helped to pop over (of course my aging body needs more reaction time
![Rolling Eyes :roll:](/phpBB3/images/smilies/icon_rolleyes.gif)
Directly onshore can be tough with a short period esp. Not sure about the back foot thing or how that would help, tough to keep the board straight and level.....thinking if you are underpowered this would be difficult....but it sounds like you have sufficient wind so don't jump off the top but slow the board so you don't go flying! You should be able to land/ride down into white water without feet in straps if you do this, bear off, gain speed and put feet in....I always have my front foot in, back out to absorb/balance when light. You are a beginner lake sailor....Are your straps wave positioned?? cuz if they are outboard instead of board centered you will have all kinds of problems getting into them in waves....as in....NEVER.
Bearing off gives you more speed as well as time between waves to get that second foot in.
Timing of sets, practice practice practice of riding up and over, absorbing the lip impact and getting ready to be leaning forward once over the lip sounds like a good plan. Sometimes when really bad on a longer shallow beach you can perhaps walk the rig past the break or body drag thru it.....like at Willows on a bigger day...once past the break water start away
you have your answer, it's not ....necessarily..... you. Wave board time or drill/epoxy in another set of inserts. Chances are your board shape tho sucks too for this type of condition. Ocean vs Lake different worldbamfieldave wrote:Hmm, foot straps are in an outboard position. Crap, there are no inboard Options unless I start drilling new holes?!
