Ideal Windsurf / Kiting Vehicle?
would be a nice project for someone.
http://www.usedvictoria.com/classified- ... -_28132130
voodmon
re- unimog
Unread post by voodmon »
It even comes with a front mounted Wench :roll: :lol:
http://www.usedvictoria.com/classified- ... n_28167188 Just remove the rear bench in the summer bolt in a hunk of plywood from the front of the engine compartment to the back of the middle seat. Carve a hatch in it & you can relive the 80's with a sweet 6 foot raised bed & storage galore :idea: :!: Future subi, ford ( http://www.bostig.com/faq/ ) or even v.w. power plants await you in your groovy adventure wagon :P Image
rvanderbyl
Unread post by rvanderbyl »
Here is a nice one of a kind family rig.
http://www.ebay.co.uk/itm/1968-Morris-T ... 2341126671
Anyone have something similar? I'm looking at replacing the vanagon, with something along these lines?
rvanderbyl
I actually thought this was my old 84 dodge 1/2 ton when I saw the pics. These are awesome vans and likely has the 318 engine. This one is still fresh if the mileage is correct. Only things to look a little closer at woud be body rust. Everything else is pretty self explanatory.
rvanderbyl wrote:I actually thought this was my old 84 dodge 1/2 ton when I saw the pics. These are awesome vans and likely has the 318 engine. This one is still fresh if the mileage is correct. Only things to look a little closer at woud be body rust. Everything else is pretty self explanatory.
They can handle the malhat and modern highway cruising fine?
rvanderbyl
These vans have power to spare for most highway driving and should cruise up the Malahat with ease. Cruising at 110-120 is no problem even with a load of camp and windsurf gear. Even La Ventana should be within range. Seems odd that it only sleeps 2. Mine with the identical raised roof slept 2 up and 2 down. So I'm thinking they converted the upper bunk to storage :idea: If so...that could be gutted and a lot of sails, booms and maybe even boards could fit inside up top. I could be wrong cause the layout looks like it could be a bit different than my 84.
BenB
Unread post by BenB »
