Windsurf Foiling Discussion
BigD
Gorge Windfoiling
Unread post by BigD »
I have a Wizard V3 130L on order, hoping to get it in the next few weeks:
Summer Goals:
https://youtu.be/WJMlcLhm3y8
Slingshot Phantasm info(not released yet):
https://webcache.googleusercontent.com/ ... clnk&gl=ca
Has thanked: 10 times
They keep banging on about shims being less efficient without addressing that shims are a tuning tool used on every race foil made.
Also a lot of statements about being "stiffest on the market" without any measurements.
Like most Slingshot stuff it's long on promotion and short on facts.
Re: Gorge Windfoiling
BigD wrote:I have a Wizard V3 130L on order, hoping to get it in the next few weeks:
Summer Goals:
That guy sails like a hummingbird with ADD. Mostly in a good way. 😄
Has thanked: 24 times
Greg Glazier looks like another young guy who can learn new things quickly. Doubt he's over 60.
firstonlastoff
Someone speculate. What volume of Wizard was Greg using ? ( I am referring to the video posted above by BigD ).
Bobson
Has thanked: 27 times
Been thanked: 18 times
Wizard 90
Unread post by Bobson »
There are only 3 so pretty sure it's the 90 litre.
+ I saw another video where he says he uses a longer mast...115 or 125cm long and the 84 front wing.
BigD
volume
Well the sail is a 2.8 so I would guess the 90L version.
If you scroll down on this page there is a great comparison of the older 125L vs the new 114L:
https://bigwinds.com/products/2021-slin ... oil-board/
I'm hoping the 130L will have enough volume for my fat ass, I'll probably look more like a dancing bear than a hummingbird. Better start eating salads now.
Has thanked: 4 times
He also crashes:
https://www.youtube.com/watch?v=XHZmDxihTU8
Look at the length of the Phatasm mast!
Bobson
Wizzard
The board is a proto I think, 4’11” and 101 litres.
KC7777
Foil combo boards
Unread post by KC7777 »
Hey,
Wondering....
I was originally hoping to get one board that could do windsurf foiling and wing foiling...with one interchangeable foil system (double track not tuttle).
Tuttle is dumb as you are stuck where the foil goes?
But I don't think that is possible? One thing I am noticing....is that windsurf foil boards mostly use tuttle, and are more rear mounted. Even the Slingshot BigD just bought, which has the two tracks system (instead of tuttle) has them placed farther back, towards the tail of the board.?
Whereas, all wing boards use two tracks, placed more forward towards the centre of the board.
Seems that a windsurf foil board has the foil mounted farther back than where you mount your foil for winging. Makes sense I guess as windsurfing you have both the mast and you on the board, and you are hanging out to the rear...winging you are standing right on top of the board.
So if you ever want to use just one board, eg for both wing and windsurf, I think it's hard to find a board right now that would do both...without buying two foils!!
Eg here is the Starboard X-Wing....the tuttle box is at the back for windsurfing and the twotrack system in front for wingfoiling. Great if you have 2 foils...a tuttle and a double track. Say you get an Armstrong wing for foiling, which is the double track to mount to the board, and get a longer fuselage and smaller front wing for windsurf foiling, I wonder how it would windsurf if you were running the windsurf foil in the track system, which is way forward?
Which is why I think you need two boards. And likely two foils?
Anyone else think of a good two in one board?....with one double track foil system. I think the board would need two A-tracks that are much longer?
You can get twin track top plates for tuttle masts, but I agree a double set of tracks would work perhaps even better.
BigD
Slingshot
I know grantmac is a huge Slingshot fan :wink: so I thought I would mention the Hoverglide fuselage can be switched around (C position) to get the infinity 76 wing further forward. I usually run the 84 in C position so would have to rely on tracks all the way forward for that wing.
Would be nice to get one setup to do it all but I think once you get proficient at the wing you'll likely want a pretty small board to make it more maneuverable. Likely too small to windfoil unless you are at in the Gorge
Long fuselages are pretty horrible to wing with in my experience. You lose a the pumping capability. I tried it with the long Supercruiser fuselage.
But you can get the short Slingshot fuse pretty cheap.
voodmon
KC777
Unread post by voodmon »
I have a 2018 Fanatic Gecko 133 Foil , i bought used locally, my biggest sail is a 5.7m2 and i have the fanatic H9 foil, but have never used either, either it's too windy or i am working and i am older 65 going on 66, glad to hear that zee Blast is working for you, I would just be happy to be blasting around with the 5.7m2 on the finned Gecko! Cheers!
The Slingshot switch fuse and small and large fuse gives a lot of versatility, even with a tuttle.
