Windsurf Foiling Discussion
Bobson
Has thanked: 27 times
Been thanked: 18 times
Unread post by Bobson »
Unread post by smartang »
Been thanked: 21 times
firstonlastoff wrote: Wed Apr 06, 2022 1:04 pm Looking more right now at opening up the low end which for me means 10+ knots ish that English Bay gets reasonably often each month.
I think for light wind foiling anything smaller than a 1500 is going to be challenging, almost frustrating, that's what I found anyways. I have the Sabfoil 1100 ( 2100 sqcm ) and the 790 ( 1550 sqcm ). You can take it for a test drive if you want. I have the aluminium 95cm mast and 900cm fuse, which is great for wind foiling that I don't use anymore.
otisdadog
Unread post by otisdadog »
Hello All,
Has thanked: 10 times
otisdadog wrote: Tue Apr 12, 2022 10:26 am Hello All,
Looking for just board and foil or also sails etc? What do you weigh?
otisdadog
grantmac wrote: Tue Apr 12, 2022 1:23 pm
Just looking for board and foil, I weigh 185lbs.
BigD
Unread post by BigD »
Hey FOLO!
OR
Moses/Sabfoil 790
Pros:
-a bit less expensive
Cons:
-a bit of an older design
See you out there!
firstonlastoff wrote: Wed Apr 06, 2022 1:04 pm seeking comment on any or all of the following;
Has thanked: 4 times
I have an H2 kicking around if you want to have it Tempy.
Re: WINDSURF foiling
Bobson wrote: Tue Apr 20, 2021 11:49 am Interesting this thread started in July of 2018 and lasted until July 2019. Seems like when most doods started the WIND foiling and now the WING foiling is starting to possibly take over. I started WIND foiling in June 2020 so I'm a bit late to the party but trying to make up for my late entry. :)
So I thought I'd try to resurrect this discussion, although many have experience WINDfoiling but are now 'trying' WINGfoiling. I would like to try the WING-THING one day but for right now I'd like to complete my fully foiling gybe and get it on camera first and make some advances in my speed over 40 km/h. …..
See you 'over' the water,
BOBSON!! (yes, you have to yell it) :)
lol I’m 4 years behind your several years Bobson!
Back problems pumping a windsurfer huge (5.9) sail onto a plane at China Creek or not having enough for my 12m kite or watching Sandy Beach having fun while I drank too many beer on a beach that was way too hot!!
I bought winging gear trying to make it work on a windfoiler with mixed success.
Tons of variables in set up to sift thru and the uphauling sucks …so I’m sailing overpowered, overfoiled and overboarded but at least gybing seems fun so far
Bobson
I'm sure you'll catch up quickly KUS, you've got that same 'stick-with-it-ness' where improvement comes quickly.
The Windfoiling is definitely easier than Windsurfing. Once your making your jibes it's sooooo easy, not coming off the foil is Rule #1 now.
I learned Winging with a Wing on my Big Windfoil board. It wasn't perfect but having a big enough board to be able to balance on it, especially in turns made it easier I think as I wasn't in the water all the time having to climb back onto the board. Bigger board better for learning.
It an interesting dilemma, you need a bigger sail to get on foil but once your up on foil, then you want 40% less sail. I sometimes need a 6m to get up but then would rather have a 4.5m to continue.
I'm hoping to see you @ Pipers and CC/NN this spring and summer. I'll be putting in some extra time this spring to improve my Winging skills.
Ding!
Re: Windsurf Foiling Foil Set Up
I understand to start you want
-the sail mast 44” ahead of the front tuttle screw or 43” front of foil mast. When going bigger sail you move the mast base back??? In windsurfing it’s the other way?
-front foil should be centered between centers of footstraps
-foil mast should be perpendicular? to board bottom ahead of the mast
- longer fuse and mast the steadier and more reaction time you have to avoid overfoil (breach)
1- Using wing foils I can’t seem to get the
Front foil centered but it’s 14.5” from front strap and only 7.5” from rear…I can move front strap back 3” unlike preferred windsurf stance or I can move the foil mast forward up to 3”….both of those options seem wrong!!
Front wing foils on both start almost right at the foil mast leading edge, no adjustments possible to move ahead but I could use my tuttle box plate to move the mast and foil ahead
2- My foil mast is leaning back 1/4” and I can correct with a 1/8” shim to vertical
3- I have a 74 and 78cm fuse, able to lengthen one to 90cm for the rear wing to be further back and get more stability
4- Masts are only 70cm but I have an 80 for the larger foil to gain more up/down leeway
So far the 2000 foil seems way huge with 5.3m sail at 12-14kn and the 1300 great til about 15-16kn, 4.7m sail, both like to overfoil but I’m getting better. Waterstarts seem to be the overpowering threshold for both so either I need to reduce foil size or have to uphaul which really sucks in waves and swell.
I can gybe the 1300 pretty well, the 2000 is a nosedive nightmare, why? I can understand an overfoil, not the nose dive….
Anybody got any comments? Priority fixes? Comparative measurements? Especially can I move the foil mast ahead to center the front foil between straps?? Thx :D
