New Wing Handles
Been thanked: 21 times
New Wing Handles
This looks interesting.
Re: New Wing Handles
Has thanked: 10 times
Unread post by smartang »
Has thanked: 24 times
winddoctor wrote: Sat Mar 09, 2024 1:30 pm Clever design! Go Pro mount is pretty slick too. DW paddle option is brilliant.
Do you have to use a screwdriver to get the paddle off?
slake
Unread post by slake »
slake
smartang wrote: Mon Apr 01, 2024 8:14 am If you had a huge dw board and a foil that did not require too much pumping, then maybe?
smartang wrote: Mon Apr 01, 2024 8:14 amBut I can promise, as a wind person the first time you're 2km offshore without windpower in overhead swell.... loss of words from my first deflate dw shocker ptsd.
smartang wrote: Mon Apr 01, 2024 8:14 amBasically the same setup that you can calmly pack down and dance around on in flat water or organized swell will be dropping out from under you, board sinking and rolling, the paddle will feel like it's stuck in cement as your shaky legs struggle to stand up for more than a few seconds. Don't forget to pack a mini pump too as an out.
The visuals are great...this is not easy. That fellow who has the three bungees on the back of the lifejacket looks like a decent idea, but still not easy.
smartang wrote: Mon Apr 01, 2024 8:14 am I still think the best beginner training is wing throws in lake swell (pre req: flat water paddle ups), put a 1lb weight on the wrist leash, and just let it go. If you have a good dw board you'll pass the wing and be waiting for it whenever your legs give out from pumping. The ride back upwind should give your shoulders and legs enough rest for another go.
This might be what I try but if the conditions are good I'll likely just wing. Didn't know what you first meant by 'wing throws' but now it is clear. I'll dig around more on this topic but do you know if one can one pump on flat water with an Armie HS1850/72 cm mast? or is that a waste of time even with a good DW board?
Atomic-Chomik
Where in the video is the paddle option?
Atomic-Chomik wrote: Thu Apr 11, 2024 4:40 pm
8:07
