Windsurf Foiling Discussion
BigD
Post by BigD »
Forget the 44" stuff, that's from 2018.
Where the foil mast is located is irrelevant. Put your front footstrap where you want it, definitely inboard to start and lose the back footrap altogether, your back foot should be scooching around for balance and to adjust pressure. Back footstrap is only used for pinching up wind. Back foot is usually centered ish on the board on a broad reach.
Cnter the front foil between your feet and adjust from there to try to get even foot pressure.
2000 is a big slow lifty foil. Get into some higher aspect foils for light winds,(slingshot ptm926, sabfoil, f4) You'll need to pump them as they won't just elevate you like a giant wing. Higher architect foils will glide through lulls.
Once your foil is balanced don't move it when you change sails, Instead push the sail mast base forward for larger sails. Back for smaller.
Use your 80cm mast it'll give more recovery time. Most use 90+ for windfoil. Use your long fuse. About 90+- is good for windfoil. Shorter for wingfoil.
Good luck.
Post by smartang »
Big thick older low aspect foils have a ton of drag. They're meant to under constant low power. The second you let off the sail/wing/kite the foils drag takes over. Add to that the high board swing of an unpowered windfoil setup and the nose drops out. A wider stabilizer and longer fuse could help reduce this effect. But that will also make it harder to overcome the overfoil on the high end.
On the other hand, the thick high aspect pump foils like Sab 1350 nose down under excessive power and buck you off the back right before a stall at nearly dead stop.
Priority one is front wing between the straps and most people prefer the wing towards the front foot.
A slight back lean in the mast is good. Don't shim that.
The 44" thing is old news, I liked 35-38" with sails under 6m.
Use the 1300cm.
BigD wrote: Fri Jan 10, 2025 8:13 am Forget the 44" stuff, that's from 2018.
Where the foil mast is located is irrelevant. Put your front footstrap where you want it… lose the back footrap altogether,…
Use your 80cm mast…Most use 90+ for windfoil. Use your long fuse. About 90+- is good for windfoil. Shorter for wingfoil
Yeah the 44 relates to the box which I will have to ignore since I am using a wing foil right at the mast & shorter fuse
That’s what I needed to hear, ignore the foil mast!
Straps are done! …except I like the back strap, feels solid
I like “get into”… more foils, lol, at those prices I think I’ll make do for a few more days :lol:
Yes moving sail mast up sounds more like it (internet says otherwise in a couple spots)
Yeah I’d like the 80 mast next time out and will order a 90. This Wingfoil set doesn’t offer a longer one. Thx for your thoughts! :D
smartang wrote: Fri Jan 10, 2025 10:54 am Big thick older low aspect foils have a ton of drag. They're meant to under constant low power. The second you let off the sail/wing/kite the foils drag takes over. Add to that the high board swing of an unpowered windfoil setup and the nose drops out. A wider stabilizer and longer fuse could help reduce this effect.
I think the 2000 was way overpowered and I was trying early sailflips because it was shooting rapidly into the gybes, will try more in lighter winds and with longer fuse, thx, later the HA foil
grantmac wrote: Fri Jan 10, 2025 12:24 pm Priority one is front wing between the straps …
Use the 1300cm.
Yep what I thought, now I’ll adjust the plate!
Thx, won’t shim for now but I also feel board is riding nose up a lot, maybe try this after adjustments
35-38 from what? Tuttle bolt? If I move things up the foil mast will be 38-39” :) so ok, sounds close!
The 1300 is great…when it’s windy…, don’t have a longer mast for that one, my next toy is a high aspect 1800 tho, see how that goes for speed using longer fuse and better front wing position…I got the 1800 instead of the 1400 as it was recommended for the bigger person….guess wind vs wingfoil? Tho I don’t see anyone using more than 1500 really …groan :?
Longer fuselage is good, bigger tail with up or down swept tips is good too. It sounds like everything you have is for winging which usually has a lot less directional stability.
Yep! That’s the issue, no windfoil gear…or at least no fuse/space in front of foilmast/tuttle with plate not very adjustable :?
I didn’t want both kits! On the upside, I managed to move the foil mast ahead 3”, rear straps back 1”, Center of front foil now at midpoint. Longer fuse set for the larger foil sets. Now I just need to avoid bolt or plate failure so I don’t litter the ocean floor!
Now of course no wind for over a week :|
Working on getting another board with a track setup to have better strength/adjustment.
The thing is you kind of need the different fuselage dimensions to make each work. I've gone as far as machining custom fuselages to get foils to ride correctly.
Even harder when you don't know what correct looks like.
Something like a Slingshot PTM926 with both fuselages would be a good investment (probably better than a board) and is widely available used.
grantmac wrote: Sun Jan 12, 2025 9:00 am ….kind of need the different fuselage dimensions to make each work. ….
custom fuselages to get foils to ride correctly, .. harder when you don't know what correct looks like.
well if the position of the foil mast doesn’t matter and length is adjustable, it truly just comes down to overall fuse length….and some windfoil at 90cm (up to 115?) which is where my modified one is now at….
Indeed this experimenting is of limited fun when you don’t know where goal posts are
They ARE readily available….for 12-1500US…not all that windfoil curious & got 4 wingfoils already…lemme know if you find a set?
Mast position does matter though, you lose a lot of directional stability having it too far forward. It's just that is slightly less important than getting the front wing between your feet or slightly forward from that.
Why not just go winging rather than trying to windfoil with a marginal set-up.
The only thing marginal is the fuse length/spacing. As for winging my knees can’t do it I am thinking, wanna learn to be on foil before I try more
~~~~~4j~~
Post by ~~~~~4j~~ »
I haven't tried this yet, but I like the theory. I plan to try this to at least get the mast close to the right spot. I'm not sure how this will work for winDfoiling, but one would think it should be similar.
Greg at Omen Foils: Finding the Perfect Track Position for Your Foil
I too have more wingfoil-oriented foil gear, but I might try foiling with a sail since the Goya Airbolt can do both. Though my longest fuse is 70 cm...
Thank you to ThePope for pointing to the Omen youtube channel. Specifically:
Thx 4j, yeah I pieced that mostly together and THEN saw the vid, good find and confirmation. The short fuse I can see making this a bit trickier but not impossible I think.
Not sure how the foil mast and turning fits into the picture but I’d think there is also a shifted “rudder” element/factor if we move stuff forward. I’ll report back but even with the foil in the wrong spot I had long rides and no problems gybing really except the huge 2000 foil.
Stubbornly sticking to my wing foil set up for wind foiling. After having some good success, yesterday was a setback, overfoiling and totally too powered I think. I felt I should still have been able to control it and even managed a couple of gybes in heavier wind with a 4.7 and 1300 but I was just way too juiced. All in an effort not to have to uphaul, which to me is the biggest downside of wind foiling. I takes way too much energy! And in waves/big chop it’s not a 100% success rate.
I can climb the foil to help waterstart but still need the sail lots to get up on the board. I can manage the shorter fuse with balance and it’s now centered. I’m in the straps and lines for locking in….point into the wind in the gusts, suck up the waves with that only 70cm mast and can avoid the wave top kisses. But I still consistently over foiled repeatedly. Could feel it coming and despite all efforts short of dumping sail power couldn’t stop it. Wouldn’t have thought a 4.7/1300 combo was too big for 16-21? knots. There was no non-foil time lol except after smackdowns which I all survived but it’s not fun.
I’d love to try another foil/board kit where someone is having a combo success beside me and prove it’s me that’s the problem :/ I thought I gained, not lost weight recently from my 205?
At same time two wings were out, big beginner guy doing ok with 2000, smaller guy with 1300 riding well, both on 5m? I guess I couldda rigged a 4.2 but uphauling sucks and I don’t have a smaller foil :(
I think you're butting your head against an unbalanced foil setup Kus. Not excess front wing size or anything else other than a fuselage too short and wing too far back.
Board too small if uphauling is difficult, should be dead easy with a foil under you.
