Windsurf Foiling Discussion
- BigD
Forget the 44" stuff, that's from 2018.
Where the foil mast is located is irrelevant. Put your front footstrap where you want it, definitely inboard to start and lose the back footrap altogether, your back foot should be scooching around for balance and to adjust pressure. Back footstrap is only used for pinching up wind. Back foot is usually centered ish on the board on a broad reach.
Cnter the front foil between your feet and adjust from there to try to get even foot pressure.
2000 is a big slow lifty foil. Get into some higher aspect foils for light winds,(slingshot ptm926, sabfoil, f4) You'll need to pump them as they won't just elevate you like a giant wing. Higher architect foils will glide through lulls.
Once your foil is balanced don't move it when you change sails, Instead push the sail mast base forward for larger sails. Back for smaller.
Use your 80cm mast it'll give more recovery time. Most use 90+ for windfoil. Use your long fuse. About 90+- is good for windfoil. Shorter for wingfoil.
Good luck.
Good luck.
Big thick older low aspect foils have a ton of drag. They're meant to under constant low power. The second you let off the sail/wing/kite the foils drag takes over. Add to that the high board swing of an unpowered windfoil setup and the nose drops out. A wider stabilizer and longer fuse could help reduce this effect. But that will also make it harder to overcome the overfoil on the high end.
On the other hand, the thick high aspect pump foils like Sab 1350 nose down under excessive power and buck you off the back right before a stall at nearly dead stop.
Priority one is front wing between the straps and most people prefer the wing towards the front foot.
A slight back lean in the mast is good. Don't shim that.
The 44" thing is old news, I liked 35-38" with sails under 6m.
Use the 1300cm.
Use the 1300cm.
Yeah the 44 relates to the box which I will have to ignore since I am using a wing foil right at the mast & shorter fuseBigD wrote: Fri Jan 10, 2025 8:13 am Forget the 44" stuff, that's from 2018.
Where the foil mast is located is irrelevant. Put your front footstrap where you want it… lose the back footrap altogether,…
Use your 80cm mast…Most use 90+ for windfoil. Use your long fuse. About 90+- is good for windfoil. Shorter for wingfoil
That’s what I needed to hear, ignore the foil mast!
Straps are done! …except I like the back strap, feels solid
I like “get into”… more foils, lol, at those prices I think I’ll make do for a few more days
Yes moving sail mast up sounds more like it (internet says otherwise in a couple spots)
Yeah I’d like the 80 mast next time out and will order a 90. This Wingfoil set doesn’t offer a longer one. Thx for your thoughts!
I think the 2000 was way overpowered and I was trying early sailflips because it was shooting rapidly into the gybes, will try more in lighter winds and with longer fuse, thx, later the HA foilsmartang wrote: Fri Jan 10, 2025 10:54 am Big thick older low aspect foils have a ton of drag. They're meant to under constant low power. The second you let off the sail/wing/kite the foils drag takes over. Add to that the high board swing of an unpowered windfoil setup and the nose drops out. A wider stabilizer and longer fuse could help reduce this effect.
Yep what I thought, now I’ll adjust the plate!grantmac wrote: Fri Jan 10, 2025 12:24 pm Priority one is front wing between the straps …
Use the 1300cm.
Thx, won’t shim for now but I also feel board is riding nose up a lot, maybe try this after adjustments
35-38 from what? Tuttle bolt? If I move things up the foil mast will be 38-39” so ok, sounds close!
The 1300 is great…when it’s windy…, don’t have a longer mast for that one, my next toy is a high aspect 1800 tho, see how that goes for speed using longer fuse and better front wing position…I got the 1800 instead of the 1400 as it was recommended for the bigger person….guess wind vs wingfoil? Tho I don’t see anyone using more than 1500 really …groan
Longer fuselage is good, bigger tail with up or down swept tips is good too. It sounds like everything you have is for winging which usually has a lot less directional stability.
Yep! That’s the issue, no windfoil gear…or at least no fuse/space in front of foilmast/tuttle with plate not very adjustable
I didn’t want both kits! On the upside, I managed to move the foil mast ahead 3”, rear straps back 1”, Center of front foil now at midpoint. Longer fuse set for the larger foil sets. Now I just need to avoid bolt or plate failure so I don’t litter the ocean floor!
Now of course no wind for over a week
Working on getting another board with a track setup to have better strength/adjustment.
The thing is you kind of need the different fuselage dimensions to make each work. I've gone as far as machining custom fuselages to get foils to ride correctly.
Even harder when you don't know what correct looks like.
Something like a Slingshot PTM926 with both fuselages would be a good investment (probably better than a board) and is widely available used.
well if the position of the foil mast doesn’t matter and length is adjustable, it truly just comes down to overall fuse length….and some windfoil at 90cm (up to 115?) which is where my modified one is now at….grantmac wrote: Sun Jan 12, 2025 9:00 am ….kind of need the different fuselage dimensions to make each work. ….
custom fuselages to get foils to ride correctly, .. harder when you don't know what correct looks like.
Indeed this experimenting is of limited fun when you don’t know where goal posts are
They ARE readily available….for 12-1500US…not all that windfoil curious & got 4 wingfoils already…lemme know if you find a set?
Mast position does matter though, you lose a lot of directional stability having it too far forward. It's just that is slightly less important than getting the front wing between your feet or slightly forward from that.
Why not just go winging rather than trying to windfoil with a marginal set-up.
The only thing marginal is the fuse length/spacing. As for winging my knees can’t do it I am thinking, wanna learn to be on foil before I try more
I haven't tried this yet, but I like the theory. I plan to try this to at least get the mast close to the right spot. I'm not sure how this will work for winDfoiling, but one would think it should be similar.
Greg at Omen Foils: Finding the Perfect Track Position for Your Foil
Thank you to ThePope for pointing to the Omen youtube channel. Specifically:
