Foil freestyle 2020? ACTION!
- Tsawwassen
Re: Foil freestyle 2020? ACTION!
Nice! Does that board come with a tuttle box for the foil or did you modify it?Erik Hakman S-1988 wrote:https://youtu.be/5pEtfJJ3wlI
My latest release! Check it out and let me know what you think!
Which foil is that?
Thanks! It's been modified to a DT and reinforced (super strong carbon). Original is a regular power box that would rip clean out of the board with all the impact.Tsawwassen wrote:Nice! Does that board come with a tuttle box for the foil or did you modify it?Erik Hakman S-1988 wrote:https://youtu.be/5pEtfJJ3wlI
Which foil is that?
The foil is the Starboard Wave 1300. Great for light wind cruising and boosting big airs!
- Has thanked: 36 times
- Been thanked: 44 times
Wow you make the upwind and dw 360s look effortless 😎 Are you using the 1300 with the 67 fuselage and do you find it twitchy at all?Erik Hakman S-1988 wrote:The foil is the Starboard Wave 1300. Great for light wind cruising and boosting big airs!
Thanks for posting,
Thanks Dave!bwd wrote:Wow you make the upwind and dw 360s look effortless 😎 Are you using the 1300 with the 67 fuselage and do you find it twitchy at all?Erik Hakman S-1988 wrote:The foil is the Starboard Wave 1300. Great for light wind cruising and boosting big airs!
Thanks for posting,
When you figure out the foil/board angles and the right leverage on the sail up- and downwind 3's are pretty simple. Not breaching is probably the hardest part. The 67 fuse is pretty quick for sure, and if you're coming from a longer fuse you might find it twitchy. I like it a lot for what I'm doing. Quick = agile!
- Has thanked: 23 times
