Chinook Windsurf Boom - $40 BWD donation
- Been thanked: 17 times
Aluminum front end with full carbon tail
Good Condition
Minimum $40 donation to BWD
I have uphaul and harness lines that can be added possibly.
- Cam
Re: Chinook Windsurf Boom - $40 BWD donation
Hi Bobson
Another summer & season for me not sailing in Victoria or Nitnaht. Bummer not seeing you. Family stuff pulled me off the water in August and much of Sept. Plus I am in W. Vancouver more than I am in Victoria.
Anyways, Are your booms still for sale? I will do a $40 eTransfer to Senor Billenness if they are and get him to msg you.
Btw I'd like the uphaul & harness lines (unless harness lines are shortees) as well if you don't need them. I never sail w/o an uphaul. Let me know if you want extra $$ for them.
After the tranaction we'll figure out the logistics of picking them up.
Regards, Cam Rawlinson
Nanaimo
Mob 250-888-3260
Nanaimo
Mob 250-888-3260
Sounds good Cam although there is only 1 boom. It’s a Chinook aluminum boom with a carbon tail. Very strong!!
- Cam
Hi Bobson . I was hoping just the boom head was Aluminium. Would you mind checking the screws that connect the head to the booms themselves (unless it a one piece alum build) . I am conerned for possible spawling (corrosion) or hairline cracks in that area (the head area) which might indicate failure is emminent.
I would intend to use them in their shorter configuation so its not so serious. Being a heavier weight sailor than you I don't want them breaking in high wind winter conditions.
Aloha Cam
Aloha Cam
