Bruised/Crack Ribs Healing Time????
Teabag
Post by Teabag »
Is there anyone here that had bruised ribs recently? Or had them bruised or broken a couple of times in their life and remember how long it took them before they could get back into kiting/windsurfing?
Most of the info on the net says 3 to 4 weeks for bruised ribs, 4 to 6 weeks for broken ribs. But it doesn’t say anything about the degree of injury so I was wondering and hoping if it happens sometimes that the ribs are bruised *just a little bit* and the healing time is a week or 2 at most?
And last question, the fact that I can do the following things is probably sign of a very small bruised right?
Day 1&2 :
- A little pain is present at the end of deep breathing or inhaling, when coughing and sneezing, but no pain during regular breathing.
- Going downstairs, walking fast or jogging hurt quite a bit, enough that I would not be able to jog for more than 3-4 min. Running would be quite painful and would worsen the injury for sure.
- Side movement of the body is ok, but going forward or backward (sit ups) hurt if done quickly, hurt a little when done slowly like tying shoes, removing boots, etc.... Inflating the kite hurt a little bit more, especially when bringing the pump handle back up.
- Push up hurt a little less than jogging. I am also able to do pull up but won't do them because the pain inflicted is enough to worsen the injury.
- Lifting heavy stuff does hurt in certain position but I can manage to find a position to lift them in a way that it doesn’t hurt as much if at all depending of the weight of the object.
- I went for a 10k hike yesterday, with a ~30 lbs backpack. It hurt a little bit almost every step, but not enough to complain about it or to worsen the injury.
Hopefully this means that it is just a minor bruised. If you have any info/comparison with your previous rib injury symptoms, please let me know. My holidays arrive soon and I need to know asap if I should push them to the right. (don’t want to waste holidays if I can’t kite).
Thanks for any info, would be greatly appreciated, Ian.
MartyD
Post by MartyD »
I broke mine almost a year ago and it hurt a lot more than what you are describing. I could not breath at all without pain for 6 weeks. If you can still hike and work out then it is probably just a light bruise. I would just take it easy for the next couple weeks and im sure it will feel much better.
I kited about 5 weeks after breaking mine when it still hurt. If you have a seated harness, take it easy, dont jump and there is not much strain put on the ribs.
Hope you are feeling better soon.
duckbill
lung
Post by duckbill »
I had a partially collapsed lung( the lung had partially separated from the wall of my body cavity) I couldn't get a full breath. rest was the cure, no activity. lasted about 3wks. If you can get a full breath( sounds like you can) , I wouldn't be concerned. disclaimer: I am not a doctor, if symptoms persist or if you experience headaches, vomiting, diarrhea, carpals tunnel syndrome, cramps, cackling, hammertoe, or an erection lasting more than ten hours, then see your doctor... immediately.
like a duck to water
BigD
ribs
Post by BigD »
I bruised and/or cracked a rib snowboarding earlier this year. I couldn't move for the first week but they slowly improved until about the 6th week when they still felt a bit weak but didn't really hurt anymore.
Sounds like you will heal up much faster if you're already hiking!
Teabag
Post by Teabag »
Thanks for all your "comparisons". I guess I got lucky and it was only a minor bruised. 2 weeks completed + 3 days (17 days total) and I can kiteboard now (with a seat harness). It still hurts a little but it is very minor.
What helped me a lot is NAPROXEN, this stuff is just unbelievable.
I took double dose for the first 2 dose, and it healed in no time.
I have read somewhere that they sell that stuff over the counter in the states, next time I go there I'll build some reserve :) I strongly advise to buy this stuff if you need anti inflammatory pills.
Cracked a few ribs on a boom in a gale a couple of winters ago. It hurt enough I went to the doctor (no situps for me!!!) Cracked or broke a few others surfing at Long Beach back in the 80s. Both times I could keep working, even packing a saw around in the bush (but had to move just right or it hurt). The last time I started windsurfing again about 5 weeks later on a light day - waist harness was pretty uncomfortable. By 6 weeks it was fine.
Truly broken ribs (complete fracture, not just cracked) would be quite a bit worse pain, with danger of doing nasty things to lungs etc when the injury is fresh, and would take another few weeks to heal.
Globe
Post by Globe »
ive got pain when i take a deep breath - been like that for a few months now - really starting to enjoy it just takes some getting used to!
heffe222
Post by heffe222 »
Healing time depends on the nature of the injury, and the location on the rib, and any other tissues involved. A direct impact to the side of the rib, without a break, will raise swelling on all the tissues around the rib, with pain, but the rib itself will recover quickly. The tissues take a while longer.
Tearing rib - sternum ligaments will take much longer to heal. I was once playing hockey on a frozen pond out on the prairies and my stick was straight ahead and was stopped by a crack in the ice. Before I could lift it free my speed carried my whole body weight into the butt end of the stick and I was lifted clear of the ice like a pole vault via my sternum. No broken bones but I tore a couple ligaments and healing took about 4 months.
Anti-inflamatories and ice and rest, until you feel better.
